kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
mdgm-ntgr
Jun 05, 2011NETGEAR Employee Retired
Under Services > Installed Addons you should see the version of ReadyNAS Remote installed. I believe the latest is 1.0.9.51.
You can download the latest version here: https://remote.readynas.com/download.html
You want the Sparc (not x86) version of the add-on. Installation is via System > Update > Local.
