kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
kingbadger
Jun 05, 2011Aspirant
I just did it - I downloaded it again using the link you provided, installed it sucessfully over the top of the previous on the NAS but still see the same message when I try to "Manage". It gees through "getting Version" then "Checking registration" then a dialog with "ReadyNAS Remote could not connect to the ReadyNAS server, please check your internet connection and DNS settings. If the ReadyNAS is behind an HTTP proxy, please make sure you have entered correct proxy server settings" comes up
Puzzling.
Puzzling.
