kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
mdgm-ntgr
Jun 05, 2011NETGEAR Employee Retired
If you look under Network > Global Settings are the Default Gateway and DNS Settings you see the NAS has picked up from your router correct?
If you download your logs (Status > Logs > Download all logs), extract the zip contents and open network_settings.log do you see a LeafNets adapter with an ip address 5.XXX.XXX.XXX?
