kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
kingbadger
Jun 05, 2011Aspirant
Yes, default gateway is showing as 192.168.2.1, as is DNS 1 (DNS 2 and 3 are blank). This is the correct IP for my router.
But no leafnets adapter - with any IP address. Below I pasted the log, but in Control panel>Network and Internet>Network Connections I can see the adapter. It is "enabled" but its status says "No network access".
eth0 Link encap:Ethernet
inet addr:192.168.2.3 Bcast:192.168.2.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:7936 Metric:1
RX packets:10953062 errors:7 dropped:7 overruns:0 frame:0
TX packets:4034786 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4152413659 (3.8 GiB) TX bytes:4092504474 (3.8 GiB)
Interrupt:41
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:2357957 errors:0 dropped:0 overruns:0 frame:0
TX packets:2357957 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:265082730 (252.8 MiB) TX bytes:265082730 (252.8 MiB)
JUMBO_FRAMES_eth0=1
SPEED_DUPLEX_eth0=AUTO_NEGOTIATION
Interrupt:41
JUMBO_FRAMES_eth0=1
