kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
mdgm-ntgr
Jun 05, 2011NETGEAR Employee Retired
So it still doesn't show a Device ID?
I guess it seems most likely that your router is blocking ReadyNAS Remote somehow.
I guess you could try the port forwarding and see if that helps.
Edit: Have you tried clearing the web browser cache e.g. Temporary Internet Files?
