kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I ha...
JarnoG
Aug 18, 2011Guide
I had a bit of problems with it at first too. Readynas remote makes it's own network adapter and my Windows classified that as a LAN-adapter. As a result the SecureW2 from my work decided it could drop the wireless connection since it now had a LAN connection and you see where that gets to be a problem... It also shut down my LAN connection btw, but I wasn't using that at that moment.
Uninstalling SecureW2 did the trick. I had to configure the wireless manually afterwards, but everything is working now.
