devilsrear
Apr 22, 2012Aspirant
Remote on Win7/Android
Hi I've gone through all the installation options, can connect on Android or windows 7 to Remote but not see anything. I've setup a "test" folder and can see it (read/write) to the folder via ft...
Ruud0511
Jul 11, 2012Aspirant
I have the same issue using Raidiator 5.3.5 for Duo V2. Did you manage to solve the problem?
