devilsrear
Apr 22, 2012Aspirant
Remote on Win7/Android
Hi I've gone through all the installation options, can connect on Android or windows 7 to Remote but not see anything. I've setup a "test" folder and can see it (read/write) to the folder via ft...
cynan
Jul 25, 2012Aspirant
Sorry for all the posts, but I got the Android client to work. I changed the FTP setting in the client by holding down the NAS icon. The only thing you can do here is enter in your FTP user/password and toggle between "anonymous" and "user mode". It was already set to "user" mode, so I thought it was a dead end. But toggling to anonymous mode and then re-toggling back to user prompted me to re-enter credentials.
For some reason, this time it worked! Now if only it would work on a port other than 21...
Is there anyway to stream files with the Android client? Without this functionality, it doesn't really do anything for you any FTP client would...
