shoei
Jan 10, 2016Aspirant
Renaming a NAS causes Replicate a lot of grief
Hi All, Well here's my latest problem - hoping I can get some very much needed assistance. The situation is this a) I have two ReadyNAS units, a 516 and a Pro 6 b) I'm running replicate...
BrianL2
Jan 10, 2016NETGEAR Employee Retired
Hi shoei,
Have you unjoined the said ReadyNAS (516) unit in the ReadyNAS replicate portal by clicking the "Remove" button? You also have an option in the device admin page to disable all ReadyNAS services (ReadyCLOUD, ReadyNAS Replicate and ReadyNAS Remote) under the cloud tab then re-enter your login credentials.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
shoei
I'll give it a try and see what happens
Thanks
Mark
