macmanleeleap
Oct 28, 2016Aspirant
Replicate issues STILL....
I have 2 readynas usnits runnig the latets firmware and they (after sorting out a p2p issue) backed up fine locally and now I have one unit offsite the backups are failing. Any advice please as I am tearing my hair out with these units. Log file is below.
2016-10-28 00:00:09
Job updated from server
2016-10-28 00:00:09
Replicate version: 1.3.0 build R2
2016-10-28 00:00:09
Starting backup job "FULL DAILY BACKUP"
2016-10-28 00:00:09
Locking target folder: /data/BACKUPS/FULL DAILY BACKUP
2016-10-28 00:00:13
Resume folder is "/data/BACKUPS/FULL DAILY BACKUP/2016-10-27 16-43 (failed)/data"
2016-10-28 00:01:05
p2p connect to nas-F6-0D-B0 in 12133640 network
2016-10-28 00:01:12
Connection method: 0
2016-10-28 00:01:12
LAN connection not available
2016-10-28 00:01:12
Using p2p connection
2016-10-28 00:01:12
Initializing source device
2016-10-28 00:01:12
Sending task to source device
2016-10-28 00:01:24
Awaiting task report
2016-10-28 00:01:29
Received success report
2016-10-28 00:01:29
Device initialization finished
2016-10-28 00:01:29
Copy in progress
2016-10-28 00:21:43
Copy failed
2016-10-28 00:21:43
Rotate backups (10)
2016-10-28 00:21:43
Rotation marker is "2016-10-20 00-00"
2016-10-28 00:22:20
Deinitialize source device
2016-10-28 00:22:20
2016-10-28 00:22:27
2016-10-28 00:22:34
2016-10-28 00:22:34
Device deinitialization finished
2016-10-28 00:22:34
p2p disconnect with nas-F6-0D-B0 in 12133640 network
2016-10-28 00:22:35
Unlock target folder: /data/BACKUPS/FULL DAILY BACKUP
2016-10-28 00:22:35
Job finished
- JennCNETGEAR Employee Retired
Hello macmanleeleap,
I have some questions to ask, I have summarize them below.
- What is the model number of the ReadyNAS units?
- What is the firmware version of each unit?
- You mentioned, you now have one unit offsite, does that mean you moved one of the units to another network?
- macmanleeleapAspirant
Cannot tell you model numbers are they are both away from my location, from what I can gather that doesn't affect them too much though.
Both running latest 6.xx firmware, again not sure of numbers but the latest one that was out about a week ago. Sory for being so vague as both units are away from my location.
You may need to have someone to be able to get to the admin page of the two NAS units. This is to check if the source and destination are reachable through the Internet, their firmware version.
Please also see this article: ReadyNAS: Replicate Troubleshooting
