terryd1
Jul 21, 2016Aspirant
Replicate on a 3200
I have purchased a 516 and I want to replicate from a 3200 onto it so that I can reformat the 3200 to get advantage of the larger drives that have been fitted. Replicate installed fine on the 516 (and co-incidentally on my ReadyNAS Pro) but when I go to install the app on the 3200 it says that there is a name conflict. I have followed the threads and keep ending up in ReadyNas remote main screen and cannot find what is said to be "in the bottom right hand corner". Can somebody advise what I am doing wrong please (I don't have p2p installed/running as far as I know). Thanks in advance - Terry
- terryd1AspirantThanks for the reply. That link takes me to the addons page and when I click on the replicate app it takes me to the ReadyNAS Replicate page where I can see my other two devices (516 and ReadyNAS Pro) but I can't see where I can download Replicate, or am I misunderstanding you? Thanks again - Terry
- mdgm-ntgrNETGEAR Employee Retired
Sounds like you restored a config backup onto the 3200 from a NAS that had Replicate installed but don't have Replicate installed on the 3200.
- terryd1AspirantI seem to recall that Netgear support did get me to restore the unit at some stage. I am not sure that we ever had any apps on it, but if that is the cause of the problem, is there a way of removing the "entry" that is blocking the new installation please? I am a GUI user, but I am happy to use command line if somebody tells me how to get at it! Thanks again for the prompt reply - Terry
