MichaelR64's avatar
MichaelR64
Restarting par/unrar process on SABNZBD
Hi,
I am using SABNZBD on my NVX pro pioneer.
The unit had to restart after power loss and now has 130Gb of rar and par files waiting for the SABNZBD to process.
However that doesn't process it, it doesn't seem to know of its existence.
If i just upload the same nzb again it just starts to download the whole 45gb per movie again.
Is there some way to tell the SABNZBD to start processing the rar/par files again?
  • WhoCares? wrote:
    Generally with
    par2 r <name of par2 file>
    Optionally you can specify what files to repair. Quite obviously you should be in the directory where the files to be repaired reside before issuing the above command ;)
    -Stefan
    that easy huh... hmm shouldn't be to hard then
  • Thanx dudes,
    although its an old topic, it fitted my needs 100% perfectly!
ProSupport for Business
