cmcloughlin
Dec 10, 2012Aspirant
Root Access Denied with SSH Enabled
I am trying to get Crashpan running on my Ultra 4. To do this I need Root access via SSH with PuTTY. I have installed EnableRootSSH but when I log in as Root with my normal Admin password I get an acc...
siigna
Dec 10, 2012NETGEAR Employee Retired
System Logs > Download all Logs. Check the boot_info.log. Last line should be SSH. 0 means disabled, 1 means ToggleSSH (which requires generated password), a large number (actually a unix timestamp) means that RootSSH was successful.
You did reboot after the add-on install, right? EnableRootSSH requires a reboot to enable.
