p4v3u
Jun 28, 2011Aspirant
sanebackend support for HP PSC 2210 or Brother DCP115C
Hello,
I'm looking for some information how to get these devices working with Sane backend on Readynas Duo.
Is there any people which have it cnfigured?
regards
regards
- WhoCares_Mentor
kugar wrote: Do you mean that with a normal ReadyNAS system, it's impossible to build HPAIO without upgrading some part of the system or some libraries ?
Yeskugar wrote: Does the libraries upgrade breaks the system or some fonctions ?
Don't know. There may be some side effects for network printing via SMB/CIFS but I didn't test that.
-Stefan - p4v3uAspirantmay please publish the way to upgrade Readynas software...
there are a lot of people which can test stability, performance... :)) - WhoCares_MentorUpgradin the ReadyNAS software involves a lot of work like installing the needed compilers, compiling the software and not to mention to wait for all that to finish. If time permits I could try to bundle something up that could be installed using SSH access to the ReadyNAS but I'm not sure when I will have some spa time to do that.
-Stefan - kugarAspirant
WhoCares? wrote: Upgradin the ReadyNAS software involves a lot of work like installing the needed compilers, compiling the software and not to mention to wait for all that to finish. If time permits I could try to bundle something up that could be installed using SSH access to the ReadyNAS but I'm not sure when I will have some spa time to do that.
-Stefan
Did you had some time to try it ?
Does las version of raidiator (x86, I have a readynas ultra now) still cause problems to build HPAIO ?
