StorageCentral
Feb 10, 2022Aspirant
SC101 Storage Central Access
I am trying to access an old SC101 from any of the following pc's, Window 10, Mac, or Virtual windows XP but not having any success. Questions 1. Is there any way of logging in or accessing other t...
- Feb 20, 2022
Finally sorted, downloaded a virtual WinXP 32Bit to VirtualBox. In VirtualBox set up bridged network card to see my own network and then a Virtual shared drive. Loaded the SCM utility onto windows. Managed to transfer all my old data accross.
Thanks for all suggestions.
Marc_V
Feb 10, 2022NETGEAR Employee Retired
Welcome to the Community!
Were you able to access the data before? SC101 is pretty old and EOL but you may be able to access it if SCM is installed. The .bin file is a firmware for the SC101 you should try downloading the other link the which has the .exe file for windows
Please see this link
Though it says US only but maybe worth a try.
HTH
StorageCentral
It is very old now but was working correctly when last used. Pings OK.
I have tried the SCM 3 0 6 US Version but this will not work on 64 bit windows.
I was thinking of install a 32 bit windows virtual machine but then you run into issues with it been on another network.
Do you know if there is any way to FTP into it or any other client software.
- Marc_VFeb 10, 2022NETGEAR Employee Retired
Is the drive not showing under explorer? Do you have any LED indicators lit? any error message? If it is not accessible we may need to use SCM to set it up again.
Not really sure if there are still users of SCM, hopefully they can share steps to do.
- StephenBFeb 10, 2022Guru - Experienced User
I suggest moving this thread to https://community.netgear.com/t5/Stora-Legacy/bd-p/stora
StorageCentral : One aspect here is that Netgear ended the Stora cloud service in April 2020. https://kb.netgear.com/000061310/Announcement-Stora-cloud-service-is-ending-April-1-2020
SC101 or Storage Central Manager does not connect to Stora service to access its data, using SCM Utility will setup a Network drive to be accessed by the user. Storage Central is a SAN,
It seems that the SC101 you have may need to be setup again but since SCM cannot be installed on your 64-bit PC you may have to try using 32-bit but it shoud install. Support have ended since it is EOL so we may not be able to expect any updates on the installer and firmware
You need to have it setup as a Network drive, have you tried accessing it on explorer using its IP address?
