jonbloke3276
Jan 28, 2024Aspirant
Shared folders disappeared RN3138
Hi, Hoping someone can point me in the right direction here. I'm currently using a ReadyNas 3138 as a Plex media server and general all round file server. Had it a couple of years and until r...
jonbloke3276
Jan 29, 2024Aspirant
I'll have a look at how i can backup all the contents of the NAS first then. It's going to take quite large storage for that.
I've read the instructions via the gitlab link, however, I'm a little new to using ReadyNAS Terminal. Do i need to enable root SSH access first, as in the attached screenshot? Apologies but you might have to dumb this down for me as much as poss, only familiar with Mac OS.
Thanks for the help so far.
Jan 29, 2024Guru - Experienced User
Yes. Last time I looked the certificate for the script was expired. But after you log in as root (using the NAS admin password), you can use these commands to execute it:
# cd //
# wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh
# chmod +x ./share_lun_ui_fix.sh
# ./share_lun_ui_fix.sh
(The # prefixes are the end of the NAS ssh prompt, you don't actually enter those)
- SandsharkJan 30, 2024Sensei
StephenB wrote:
Yes. Last time I looked the certificate for the script was expired. But after you log in as root (using the NAS admin password), you can use these commands to execute it:The current instructions don't require a certificate. They tell you to paste the text into a document created with VI (so it has LF-only EOL's, not CRLF's). I did that and put the file in my dropbox. Then you just execute in locally instead of with wget.
- StephenBJan 30, 2024Guru - Experienced User
Sandshark wrote:
In my instructions, wget is just downloading the script (so no need for vi). I then execute it locally.
