TeknoJnky
Apr 07, 2013Hero
sickbeard, readynas remote/leafnet, wombles
forever I have had errors from sickbeard regarding wombles index. after some investigation, I discovered that nzb.isasecret.com I can ping from my pc, but the readynas's can not. Z:\d>ping nzb....
Apr 08, 2013Guru - Experienced User
When Leaf first began operations, 5.x.x.x was reserved for "experimental use" by IANA so it was safe to use for the VPN address scheme.
When IPv4 addresses started becoming scarce, it was re-allocated, so it could be (and now is) used for internet addressing. Netgear needs to switch the leaf adapter to use a private address space. But they never have, even though the 5.x.x.x addresses were reallocated a few years ago.
