Jaap74
Jan 13, 2012Aspirant
Songs not playing in correct order on Twonky
Hi,
Just installed Twonky on the ReadyNAS Duo with some help from this kind board however the songs in albums don't play in the correct order. I had the same issue when I had Twonky on my PC so I downloaded some changed XML files and copied to the Twonky C: folder and it correct the problem.
How do I do the same on the Twonky server on my ReadyNAS ?
Thanks
Thanks
- mdgm-ntgrNETGEAR Employee RetiredHave you had a look in the "twonkymedia" share? If you connect to the NAS using CIFS (also known as samba) i.e. via Windows Explorer as "admin", you should see a "c" share. Inside that will be a twonkymedia folder. I think there might be one or two other folders in the "c" share to look at as well.
- Jaap74AspirantThanks mdgm. I think I have a lot of reading to do. I know absolutely nothing about Linux or SMB so will have to start from scratch I guess.
Looks like I'll be using Twonky via my PC for a while yet ! - mdgm-ntgrNETGEAR Employee RetiredJust think of CIFS/SMB as accessing the NAS via Windows Explorer. It's Windows File Sharing.
- Jaap74AspirantActually it was simpler than I thought, I found the XML files and have replaced them :-)
