itsupportnl
Jul 19, 2013Follower
Source device doesn't support 'Backup System'
I'm on /replicate.readynas.com and I'm tryin to 'Backup System' from a Readynas 102 to a Readynas 316 but in the wizard I have error: Source device doesn't support 'Backup System' I did enabled:...
Jan 20, 2014Guru - Experienced User
If the NAS and the backup server are on the same network, you can use a group of frontview backup jobs.
For instance, one backup job for each shared folder, and one backup job for the "home" directories. It is harder to restore the "home" directories, because there is no one-step recovery mode. You can restore them, it is just annoying because there are multiple steps.
