itsupportnl
Jul 19, 2013Follower
Source device doesn't support 'Backup System'
I'm on /replicate.readynas.com and I'm tryin to 'Backup System' from a Readynas 102 to a Readynas 316 but in the wizard I have error: Source device doesn't support 'Backup System' I did enabled:...
Leia
Apr 17, 2014NETGEAR Employee Retired
This “Backup System” option is only for the older ReadyNAS units and not needed for the new platforms. It is still present in the application for legacy support. If
you want to backup the entire system, create a job and select the volume you want to back up.
Thanks,
-Leia
Thanks,
-Leia
