Pixeltje
Aug 31, 2011Aspirant
SSH on NV+
Hi, Since i can't find any topic related to the " enable Root SSH addon" i'll give it a shot here; I've installed the addon on my NV+ to figure out why transfer rates are so low (tried to use 't...
mdgm-ntgr
Aug 31, 2011NETGEAR Employee Retired
The EnableRootSSH add-on is not a toggle add-on. It enables SSH on the unit. The way to disable it would be to do a factory reset (wipes all data, settings, everything). This will restore full software support.
If you login to SSH you can use the "top" command to monitor CPU usage.
