Pixeltje
Aug 31, 2011Aspirant
SSH on NV+
Hi, Since i can't find any topic related to the " enable Root SSH addon" i'll give it a shot here; I've installed the addon on my NV+ to figure out why transfer rates are so low (tried to use 't...
Pixeltje
mdgm wrote: The EnableRootSSH add-on is not a toggle add-on. It enables SSH on the unit. The way to disable it would be to do a factory reset (wipes all data, settings, everything). This will restore full software support.
If you login to SSH you can use the "top" command to monitor CPU usage.
Thanks for your quick reply!
The problem is, when I type "top" while connected through SSH (terminal, OSX lion) it replys with an error (thought it was 256) telling me: "Unknown terminal type"..
