Pixeltje
Aug 31, 2011Aspirant
SSH on NV+
Hi, Since i can't find any topic related to the " enable Root SSH addon" i'll give it a shot here; I've installed the addon on my NV+ to figure out why transfer rates are so low (tried to use 't...
WhoCares_
Aug 31, 2011Mentor
Sorry, just saw this topic. For the "Unknown terminal type" error, there's two ways to fix that:
1) Change the terminal type of OS X terminal app to "xterm" or
2) when connected through SSH issue the command "export TERM=xterm"
While the first solution will offer a permanent fix, the second one has to be done on every new session. The main reason for the problem is that OS X terminal by default uses a terminal type of "xterm-color" which isn't known by all Linux distribution ( and neither on Solaris for that matter). Thus they fall back to a very lowtech terminal type which explains your problems with the display of some command line applications.
-Stefa
-Stefa
