dk0r
Sep 27, 2011Guide
Subsonic 4.5.04 --Crashing
For me, instability in the Subsonic plugin has been occurring since version 1.9. The current and previous plugins crash regularly over time or upon restarting my pioneer-pro. If, after the plugin has ...
TeknoJnky
Oct 01, 2011Hero
I can confirm that 4.5.04 addon green light does not stay on, but the subsonic service itself has been running fine on my pro.
On my ultra 4 with mixed mp3/flac library, it was crashed the first few days but then started staying up for whatever reason.
Some questions, what size library do you have?
if you ssh in and check the subsonic.sh file (ie nano /c/webroot/subsonic/subsonic.sh), what is the max memory set at? mine is set for 700, my library is over 200k mp3.
Various people, including myself, have had problems with subsonic crashing since S-P came out with the addon. Mine has been stable for seems like nearly a year, tho others have still had problems off and on.
Aside from running out of memory, I'm not sure if its more of a subsonic issue or readynas/addon issue.
I don't think it matters, but I'm using the below ffmpeg and lame, from before a separate addon was created.
sauron:~# ffmpeg
FFmpeg version UNKNOWN, Copyright (c) 2000-2010 Fabrice Bellard, et al.
built on May 5 2010 09:37:32 with gcc 4.4.1
configuration: --enable-pthreads --disable-shared --enable-static --enable-gpl --enable-libx264 --enable-libmp3lame --enable-libfaad --disable-decoder=aac
libavutil 50. 8. 0 / 50. 8. 0
libavcodec 52.52. 0 / 52.52. 0
libavformat 52.50. 0 / 52.50. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
sauron:~# lame
LAME 32bits version 3.97 (http://www.mp3dev.org/)
usage: lame [options] <infile> [outfile]
<infile> and/or <outfile> can be "-", which means stdin/stdout.
Try:
"lame --help" for general usage information
or:
"lame --preset help" for information on suggested predefined settings
or:
"lame --longhelp"
or "lame -?" for a complete options list
sauron:~#
