dk0r
Sep 27, 2011Guide
Subsonic 4.5.04 --Crashing
For me, instability in the Subsonic plugin has been occurring since version 1.9. The current and previous plugins crash regularly over time or upon restarting my pioneer-pro. If, after the plugin has ...
dk0r
Oct 01, 2011Guide
..I was beginning to grow lonely
Does 4.5.04 startup without error if you reboot your NAS? Which version of Radiator are you running?
I've only about 7k flac/mp3 files viewable by subsonic.
700 here too. It seems that 700 may be default. I'll assume the units of measure are Mega Bytes and try seeing if varying the values has an affect on stability.
Contents of subsonic.sh as follows:
TeknoJnky wrote: I can confirm that 4.5.04 addon green light does not stay on, but the subsonic service itself has been running fine on my pro.
TeknoJnky wrote: what size library do you have?...my library is over 200k mp3.
TeknoJnky wrote: if you ssh in and check the subsonic.sh file (ie nano /c/webroot/subsonic/subsonic.sh), what is the max memory set at? mine is set for 700...
#!/bin/sh
# Shell script for starting Subsonic. See http://subsonic.org.
# Author: Sindre Mehus
SUBSONIC_HOME=/c/webroot/subsonic
SUBSONIC_HOST=0.0.0.0
SUBSONIC_PORT=4040
SUBSONIC_HTTPS_PORT=0
SUBSONIC_CONTEXT_PATH=/
SUBSONIC_MAX_MEMORY=700
SUBSONIC_PIDFILE=
SUBSONIC_DEFAULT_MUSIC_FOLDER=/c/media/music
SUBSONIC_DEFAULT_PODCAST_FOLDER=/c/media/Podcast
SUBSONIC_DEFAULT_PLAYLIST_FOLDER=/c/media/playlists
quiet=0
export LC_CTYPE=en_US.UTF-8
usage() {
echo "Usage: subsonic.sh [options]"
echo " --help This small usage guide."
echo " --home=DIR The directory where Subsonic will create files."
echo " Make sure it is writable. Default: /var/subsonic"
echo " --host=HOST The host name or IP address on which to bind Subsonic."
echo " Only relevant if you have multiple network interfaces and want"
echo " to make Subsonic available on only one of them. The default value"
echo " will bind Subsonic to all available network interfaces. Default: 0.0.0.0"
echo " --port=PORT The port on which Subsonic will listen for"
echo " incoming HTTP traffic. Default: 4040"
echo " --https-port=PORT The port on which Subsonic will listen for"
echo " incoming HTTPS traffic. Default: 0 (disabled)"
echo " --context-path=PATH The context path, i.e., the last part of the Subsonic"
echo " URL. Typically '/' or '/subsonic'. Default '/'"
echo " --max-memory=MB The memory limit (max Java heap size) in megabytes."
echo " Default: 100"
echo " --pidfile=PIDFILE Write PID to this file. Default not created."
echo " --quiet Don't print anything to standard out. Default false."
echo " --default-music-folder=DIR Configure Subsonic to use this folder for music. This option "
echo " only has effect the first time Subsonic is started. Default '/var/music'"
echo " --default-podcast-folder=DIR Configure Subsonic to use this folder for Podcasts. This option "
echo " only has effect the first time Subsonic is started. Default '/var/music/Podcast'"
echo " --default-playlist-folder=DIR Configure Subsonic to use this folder for playlists. This option "
echo " only has effect the first time Subsonic is started. Default '/var/playlists'"
exit 1
# Parse arguments.
while [ $# -ge 1 ]; do
case $1 in
--help)
usage
--home=?*)
SUBSONIC_HOME=${1#--home=}
--host=?*)
SUBSONIC_HOST=${1#--host=}
--port=?*)
SUBSONIC_PORT=${1#--port=}
--https-port=?*)
SUBSONIC_HTTPS_PORT=${1#--https-port=}
--context-path=?*)
SUBSONIC_CONTEXT_PATH=${1#--context-path=}
--max-memory=?*)
SUBSONIC_MAX_MEMORY=${1#--max-memory=}
--pidfile=?*)
SUBSONIC_PIDFILE=${1#--pidfile=}
--quiet)
quiet=1
--default-music-folder=?*)
SUBSONIC_DEFAULT_MUSIC_FOLDER=${1#--default-music-folder=}
--default-podcast-folder=?*)
SUBSONIC_DEFAULT_PODCAST_FOLDER=${1#--default-podcast-folder=}
--default-playlist-folder=?*)
SUBSONIC_DEFAULT_PLAYLIST_FOLDER=${1#--default-playlist-folder=}
usage
esac
shift
done
# Use JAVA_HOME if set, otherwise assume java is in the path.
JAVA=java
if [ -e "${JAVA_HOME}" ]
then
JAVA=${JAVA_HOME}/bin/java
fi
# Create Subsonic home directory.
mkdir -p ${SUBSONIC_HOME}
LOG=${SUBSONIC_HOME}/subsonic_sh.log
rm -f ${LOG}
cd $(dirname $0)
if [ -L $0 ] && ([ -e /bin/readlink ] || [ -e /usr/bin/readlink ]); then
cd $(dirname $(readlink $0))
fi
/c/webroot/subsonic/jre1.6.0_20/bin/java -Xmx${SUBSONIC_MAX_MEMORY}m \
-Dsubsonic.home=${SUBSONIC_HOME} \
-Dsubsonic.host=${SUBSONIC_HOST} \
-Dsubsonic.port=${SUBSONIC_PORT} \
-Dsubsonic.httpsPort=${SUBSONIC_HTTPS_PORT} \
-Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} \
-Dsubsonic.defaultMusicFolder=${SUBSONIC_DEFAULT_MUSIC_FOLDER} \
-Dsubsonic.defaultPodcastFolder=${SUBSONIC_DEFAULT_PODCAST_FOLDER} \
-Dsubsonic.defaultPlaylistFolder=${SUBSONIC_DEFAULT_PLAYLIST_FOLDER} \
-Djava.awt.headless=true \
-verbose:gc \
-jar subsonic-booter-jar-with-dependencies.jar > ${LOG} 2>&1 &
# Write pid to pidfile if it is defined.
if [ $SUBSONIC_PIDFILE ]; then
echo $! > ${SUBSONIC_PIDFILE}
fi
if [ $quiet = 0 ]; then
echo Started Subsonic [PID $!, ${LOG}]
fi
