ludwich's avatar
ludwich
subsonic stops
My subsonic stops working every morning now after the new update =( I had the same problem before but there was a patch that made it work but now it stops every morning even when i dont restart the nas =( ... Anyone else who have the same issue ? And if i have it running and restart the nas it stops aswell =( this sucks
Well solved it by downgrading it back to 2.0
  • If you want to start from fresh you can uninstall and select "no" to let it remove the existing configuration data when asked. If you believe the app is malfunctioning, but can't pin it down to installation files, or config - this would be the route to take. But you will have to set it up again from scratch.
    Otherwise, just install over the top of the existing one.
  • @PKAS
    I tried your solution here: viewtopic.php?f=36&t=64131#p370277
    It seemed to work for a couple of weeks, but now Subsonic is stopping again. I verified the modified per your solution and it still has the added lines. So I'm not sure why Subsonic is not auto-restarting. Any help would be greatly appreciated.
    I'm on Subsonic 4.7.04.
  • Hi -- sorry for the delay in responding. If things are still not working, let me know. In fact, if things are not working, please ssh into the ReadyNAS and type the following:
    ps aux | grep onic
    Paste the results in a reply -- we can start from there.
    pkas
  • Okay, I thought it fixed it. But it's still not working. However, running the subcheck.sh manually works.
    I edited /etc/crontab. I added the following line.
    5,20,35,50 * * * * root /home/admin/subcheck.sh
    I checked /var/log/cron.log. The script appears to be running every 15 minutes.
    Any ideas?
    Update: This has been fixed. The solution was to add /bin/sh to the cron job.
    Like this:
    5,20,35,50 * * * * root /bin/sh /home/admin/subcheck.sh
ProSupport for Business
