HomoLuna
Apr 13, 2020Aspirant
Surveillance Licence Activation
I have successfully used Surveillance on an RN102 since 2015 with three cameras. The RN102 is dedicated to surveillance and configured as RAID1 with two 1Tb discs. I have two surveillance licences p...
- Apr 16, 2020
I have reinstalled the OS, installed Surveillance from file surveillance_1.1.0-13_armel.deb and updated surveillance to version 1.1.2 . I have activated both licences online. My system configuration is now re-established as it was and is functioning properly with three cameras. Many thanks fo your help.
You may be interested to know that I deliberately used a Windows 7 PC to accomplish this rebuild instead of a Windows 10 PC.
Marc_V
Apr 13, 2020NETGEAR Employee Retired
Welcome to the Community!
Will you be able to provide me your MyNETGEAR E-mail, license numbers and ReadyNAS Serial number through PM. We will try to check on your inquiry.
Regards
HomoLuna
Yes, if I knew what PM meant
- SandsharkApr 13, 2020Sensei
Private Message. Click on his name and select "send this user a private message" form the page that opens or use the envelope icon at top right.
- Marc_VApr 15, 2020NETGEAR Employee Retired
Your licenses should have been reset, kindly try to re-activate it and let me know :)
thanks!
- HomoLunaApr 16, 2020Aspirant
