omer1143
May 21, 2011Aspirant
Teaming support for ReadyNAS Pro Pioneer with 4.2.17
Hello, I sucessfully run my ReadyNAS Pioneer Pro under 4.2.15 and I'm using the teaming add-on provided by super-poussin. The new firmware release 4.2.17 provides a couple of improvements and so I'...
omer1143
May 27, 2011Aspirant
onicrom wrote: google for 'bonding' in debian its fairly easy to setup teaming on the readynas the linux term is bonding and the mode (active/active or active/passive) is set as part of the config.
Have you ACTUALLY DONE this?
I'm quite careful with playing around with the network settings on the NAS. I don't want to lose the access to it...
I currently have a setting of 802.3ad with jumbo frames which is the fastest you can get (as far as I know).
I'm quite dependent on a fast connection to the NAS since I work a lot with pictures on my desktop (I also have a card installed with two 1GB entries which I'm bundling on the desktop end).
Is there anybody out there who has done such a configuration exercise directly on the NAS?
