hawkun's avatar
hawkun
Unable to connect to XXX, Connect error code: -501
I added a second job replicating data från NAS #1 ("Backupdisk") to NAS #2 ("Backupdisk_off"). Can't run it. I get an error that Replicate is unable to connect to "Backupdisk". Log:
[2012-05-07 17:03:29] [Info] Starting backup job "vmProtect offsite"
[2012-05-07 17:03:29] [Info] Replicate addon version: 1.0.7 build R1
[2012-05-07 17:03:29] [Info] Locking target folder: /c/Backup/vmProtect offsite
[2012-05-07 17:03:30] [Info] Making full backup
[2012-05-07 17:03:33] [Info] p2p connect to Backupdisk in 631661 network
[2012-05-07 17:03:33] [Error] Unable to connect to Backupdisk
[2012-05-07 17:03:33] [Error] Connect error code: -501
[2012-05-07 17:03:33] [Error] Please check the network connection between devices
[2012-05-07 17:03:33] [Info] Rotate backups (4)
[2012-05-07 17:03:33] [Info] Unlock target folder: /c/Backup/vmProtect offsite
[2012-05-07 17:03:33] [Info] Job finished
Replicate shows "Backupdisk" under Network and I can also browse it in Replicate.
So what is error -501 and how can I solve it? Is it something to do with the security setting on the source folder on "Backupdisk". I have one more job that is almost identical (same disks but different source and target folders) that seems to be working fine.
Thanks for any help.
  • What firmware version are you running on both of your ReadyNAS? Which ReadyNAS platforms are you using? The section of log you provided is showing an old version of replicate. Could you update to the most current version on both devices and let us know how that works?
  • Everything was updated on the source NAS but the target was still a bit old. Updated it too and now it works again :D
    Thanks!
    (I really wish that ReadyNAS and/or the Replicate application would be a bit more supportive to solve these kind of problems. It's not the first time I spend hours to find a really stupid mistake... and probably not the last.)
  • I am having same issue
    Was working yesterday - and now I get below.
    Identical Pro 4's Radiator 4.2.22 1.15 of Replicate... Both boxes on same network 45 day trial licenses
    Any idea?
    Log:
    [2012-11-29 20:39:37] [Info] Starting backup job "Data Backup [2012-11-29 11:40 PM]"
    [2012-11-29 20:39:37] [Info] Replicate addon version: 1.1.5 build R1
    [2012-11-29 20:39:37] [Info] Create target folder: /c/backup/GWFILES/Data Backup [2012-11-29 11:40 PM]
    [2012-11-29 20:39:37] [Info] Locking target folder: /c/backup/GWFILES/Data Backup [2012-11-29 11:40 PM]
    [2012-11-29 20:39:38] [Info] Making full backup
    [2012-11-29 20:39:42] [Info] p2p connect to GLAD-NAS in 1081429 network
    [2012-11-29 20:39:42] [Error] Unable to connect to GLAD-NAS
    [2012-11-29 20:39:42] [Error] Connect error code: -501
    [2012-11-29 20:39:42] [Error] Please check the network connection between devices
    [2012-11-29 20:39:42] [Info] Rotate backups (1)
    [2012-11-29 20:39:42] [Info] Unlock target folder: /c/backup/GWFILES/Data Backup [2012-11-29 11:40 PM]
    [2012-11-29 20:39:42] [Info] Job finished
  • Any update to this? I'm having the same issue.
    I'm running 4.2.22 on two ReadyNas 3200s and running the latest 1.2 Replicate software. As soon as I start the job, it errors out immediately with the same 501 error code.
  • all these error are P2P/network error. could you guys make sure "leafp2p" service running as well as all the out bound network connection OK from the NAS?
ProSupport for Business
