shaggys
Jan 28, 2010Aspirant
WAKE addon problem
Hi
Just installed the WAKE addon but when trying to wake a computer upp I get the error below.
Do I have the wrong PHP version on my DUO?
I use PHP from here
PHP5 5.2.11 from WhoCares
http://www.readynas.com/forum/viewtopic.php?f=47&t=35880
Error I get is this(I removed the mac adress -:) )
Warning: socket_set_option() [function.socket-set-option]: unable to set socket option [42]: Protocol not available in /c/webroot/wake/action.php on line 34
Le PC ayant pour adresse MAC deletedMACAdress à été réveillé !
Si vous souhaitez utiliser le controle à distance, merci de patienter quelques instants le temps que votre machine demarre.
Vous pouvez fermer cette fenetre.
I use PHP from here
- mtjoernelundAspirant
gonzo_74 wrote:
// $opt_ret = socket_set_option($s, 1, 6, TRUE);
I do not think you need to disable the above line. Just replace it with this:
$opt_ret = socket_set_option($s, SOL_SOCKET, SO_BROADCAST, TRUE);
And then it should work. (BTW, am using php5 on my readynas duo). - super_poussinVirtuosoguys,
what is the value of ip_addy ?
for example :
$ip_addy = "192.168.101.255"; - PereToinouAspirantHi poussin,
mine is 192.168.1.255. No doubt, it's the broadcast of my LAN. - shaggysAspirantmine works now. Thanks for the tip...
my net is 192.168.0.255 - super_poussinVirtuosofor people having problem with 1.0 on sparc you can try
http://www.readynas.com/contributed/sup ... ke_1.1.bin
it should not touch your settings :) - Joris1Aspirant
mtjoernelund wrote:
I do not think you need to disable the above line. Just replace it with this:gonzo_74 wrote:
No more problems here after I replaced the line above and changed the value of $ip_addy in action.php to the correct value for my LAN. Thanks mtjoernelund & super-poussin! - fabff7AspirantThat worked for me too! :woot:
Just replacing$opt_ret = socket_set_option($s, 1, 6, TRUE);
by$opt_ret = socket_set_option($s, SOL_SOCKET, SO_BROADCAST, TRUE);
is enough to transmit the magic packet! - piston_brokeAspirantAnyone got an english version of this
My PHP is limited but is better than my french
I think I'm getting there but an english version would be great
Cheers
Alain
Only the name is french - MED1975Aspirant
piston broke wrote: Anyone got an english version of this
Cheers
Alain
I'd second that! An English translated version would be very useful. Here's hoping someone has done this!
Thanks
Matt - super_poussinVirtuosoif I have time , but no guarantee
