Vernatronics
Aug 24, 2013Aspirant
Xplorer not working - connection was reset
Hi. I installed Xplorer (AJAX File Explore) by super-poussin on my ReadyNAS Ultra 2 (firmware: RAIDiator 4.2.24), but cannot get it to work. Each time I try http://192.168.1.170/explorer/ (192.16...
fastfwd
Sep 02, 2013Virtuoso
gibxxi wrote: The latest version of PHP WhoCares has posted is what's causing this issue IMHO.
For what it's worth, I'm using that recent version of the WhoCares addon without any problem. If the addon really is at fault, the root cause is probably just a misconfiguration; maybe looking at the error log will make obvious what needs to be changed:
cat /var/log/frontview/error.log | grep -i PHP
