Vernatronics
Aug 24, 2013Aspirant
Xplorer not working - connection was reset
Hi. I installed Xplorer (AJAX File Explore) by super-poussin on my ReadyNAS Ultra 2 (firmware: RAIDiator 4.2.24), but cannot get it to work. Each time I try http://192.168.1.170/explorer/ (192.16...
gibxxi
Sep 08, 2013Guide
If I was getting the error I'm seeing with JUST AjaXplorer, I'd be inclined to agree. But I'm not.
I'm getting the EXACT same error message for half a dozen add-ons, all of which are powered by (or use in some form) PHP. So it's something in the latest PHP addon that's either a misconfiguration or has the wrong credentials assigned to it, thus preventing it's use/execution. AjaXplorer has it's issues, but nothing that will prevent the UI from loading or basic functionality from working. I'm using the same add-on edition of that app now, as I was before I recently factory-defaulted my NAS, when it was working fine.
Now there could be an issue with the recent "security" changes Netgear made to the 4.2.24 FW, but if that's the case, I wouldn't know where to look. Simply downgrading to the previous firmware release doesn't cure the issue, that I do know as I tried.
