phurbatbhutia
Nov 08, 2022Aspirant
: : readynas neatgear model RN31600 SERAL NO 3WL353E000114, ERR: USED DISK CHECK RAIDar in screen P
Readynas neatgear model RN31600 SERAL NO 3WL353E000114, problem ERR: USED DISK CHECK RAIDar in screen Product: (RN31600) ReadyNAS 300 Series 6- Bay need help to solve the problem : os not complet...
Nov 08, 2022Guru - Experienced User
phurbatbhutia wrote:
backup not taken, it is in storage only.
Are you saying you have data you want to preserve? Or that it is ok to destroy the data?
phurbatbhutia
Nov 15, 2022Aspirant
thank you for the reply
Yes I want to preserve my data, which is very much essential and important date.
I am looking for help
- StephenBNov 15, 2022Guru - Experienced User
Yes I want to preserve my data, which is very much essential .
Unfortunately, it is also very much at risk, and might be lost. The error means that the NAS thinks the disks aren't formatted for ReadyNAS. This is possibly a problem with the OS partition.
I suggest that the next step is to power down the NAS and remove disk 1. Then boot up Volume read-only from the boot menu and see if this helps. (booting up read-only is important, don't boot up normally). Instructions for doing this are on page 81 here:
If this gives the same error, then power down again, reinsert disk 1, and try doing an OS reinstall. Be careful not to do a factory default.
If both of these fail, then I think you will need to use RAID recovery software.
