these2boots
Apr 05, 2013Aspirant
0 of 0mb used, offline
had a disk go bad on my NV+. replaced it with a larger disk. initially i pulled the wrong drive thinking it was 3 when in reality it was drive 4. I don't think i messed up the order at any time by...
Apr 05, 2013Guru - Experienced User
Just to be clear -
(a) drive 4 died, so you lost redundancy
(b) you then removed drive 3 by mistake, which made the array unusable
When you reinserted drive 3, was the NAS powered up?
When did you remove drive 4?
