Allard72
Jun 10, 2016Aspirant
0x80070035 fault after upgrade 6.5
After upgrade to 6.5 of My readynas Duo v2, No access to any NAS folders Access via Readycloud or connecting admin via IP is no problem. Directly from computers with Windows 7 and 10 or my Home ...
Jun 10, 2016Guru - Experienced User
If you look at the share settings, is SMB enabled?
Also, can you confirm your model? The duo v2 doesn't run OS 6.x firmware.
Allard72
Jun 23, 2016Aspirant
That's strange... The model has done a update by itself. today to 6.5.1. Model is RN10200
SMB is on
Anonymous is on at SMB
Workgroup on PC's and NAS are the same.
Connection is WIFI by the Netgear R7000 router
