Allard72
Jun 10, 2016Aspirant
0x80070035 fault after upgrade 6.5
After upgrade to 6.5 of My readynas Duo v2, No access to any NAS folders Access via Readycloud or connecting admin via IP is no problem. Directly from computers with Windows 7 and 10 or my Home ...
Allard72
Jun 23, 2016Aspirant
No, still the same problem. I have it on a win7 and win10 computer.
Tried also 6.4. Same problem
Have also put SMB on 2.1, instead of 3.0
Connecting by cloud, no problem
Connecting via Raidar - explorer, no error
BrianL2
Jun 23, 2016NETGEAR Employee Retired
Hi Allard72,
Welcome to the community!
Can you check if ReadyCLOUD is enabled? If yes, tell us if there is a similar e-mail address used by Cloud and one of the local users registered in your ReadyNAS.
Kind regards,
BrianL
NETGEAR Community Team
- nakiJun 23, 2016Aspirant
I also have the same trouble.
0x80070035
