Labdoc1
Jan 11, 2021Luminary
10 Gigabit switch for RN526x SMB network
I have a new-to-me RN526x, which has 2x10G copper ethernet ports. Currently, it is connected to a Netgear GS108E switch (1 Gigabit x 8 ports). I would like to update the network with a 10G switch and...
- Jan 12, 2021
Labdoc1 wrote:
Good to know. What is your subjective impression of the noise from the fans?
The switch is in the basement, and is co-located with other equipment (several ReadyNAS and a PoE switch). So I don't think a sound measurement (or a subjective impression) would give you any good information, given the mix of equipment.
Acoustic noise is spec'd at 36.7 dba @ 25C on the datasheet (the XS716E is a bit quieter, at 33.9 dba).
rn_enthusiast
Jan 11, 2021Virtuoso
XS708E is an "enhanced" switch, meaning it has some configuration options. However, the XS708T is a Smart switch and has a lot more features. I would pick the XS708T, personally - if price difference isn't too big.
I would however advise you visit the forums for Netgear switches and pose the question there. Both these switches are "older" models that have been out for a good few years now. There might be other options worth looking at.
Labdoc1
Thanks for the suggested posting to the network forums. I have added a post there.
- StephenBJan 12, 2021Guru - Experienced User
FWIW, I am using an XS708Ev2, and it is working well.
Though if you need more than 8 ports total, then your expected usage does play into this decision. You might want a switch that has more ports (some gigabit, others 10 gigabit).
Also, if you get a multigig switch, make sure you can set the speed manually on the switch port. The RN526 doesn't do multigig negotiation.
- Labdoc1Jan 12, 2021Luminary
Good to know. What is your subjective impression of the noise from the fans? If you have a smart phone sound level app, would you take a measurement at, say 25 cm (10")?
