marcosgu
Apr 18, 2017Aspirant
ping a gs105v4 gigabit switch
Hi guys,
First aplogies if theres already a step by step procedure on how to ping to this switch in this forum. I only have one computer available to me at the moment and I would like to simply ping a gs105 neatgear gigabit switch using a network cable. (OS windows 7)
Now I have already attempted the following things
1) using wireshark to get the ip address
No Time Source Destination Protocol Length Info
1 0.000000 192.168.137.1 239.255.255.250 SSDP 318 NOTIFY * HTTP/1.1
However, using IP address 239.255.255.250 when i ping gets me a time out error
C:\>ping 239.255.255.250
Pinging 239.255.255.250 with 32 bytes of data
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 239.255.255.250:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
2) executing an ipconfig at a command prompt
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 192.168.137.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
I get this result when hook up an ethernet cable to the switch however i get the following output when i ping to 192.168.137.1
With ethernet cable connected
C:\>ping 192.168.137.1
Pinging 192.168.137.1 with 32 bytes of data
Reply from 192.168.137.1: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.137.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
with ethernet cable NOT connected!
so obviously i know this isnt pinging to the switch either!
and so now im at a loss. Any help would be greatly appreciated. Thanks!
Hi marcosgu,
GS105v4 is an unmanaged switch.In other words, no SW on it at all. So you cannot ping the switch.
NETGEAR Employee.
- Retired_Member
Hi marcosgu,
Welcome to the community!
At first, the IP address that you get from Wireshark is multicast IP(239.255.255.250), not Switch IP address, obviously ping this IP is unreachable.
If you want to get Switch IP address, I suggest you discover switch with Smart Control Center (SCC) software. And this tool can discover, manage and login Switch with HTTP. You could download this tool from Netgear downloadcenter with below link:
http://downloadcenter.netgear.com/
EricZ
NETGEAR employee
- marcosguAspirant
Hi EricZ,
Ok thanks! ill try that and post later if it works or not
- marcosguAspirant
Ok so I installed the smart control software (v1.1.3.3) off the netgear website and when i go to "discover" i see no devices listed at all. I made sure that the ethernet connection adapter (under the adapters tab) was checked off.
I dont know if it makes a difference but I tried both ways of assigning an iP address and assigning an IP address automatically (DHCP) and both ways I see nothing listed. i saw somewhere that there is another possible software called Prosafe Plus Utility.
I am going to look and read some more.
