marcosgu
Apr 18, 2017Aspirant
ping a gs105v4 gigabit switch
Hi guys, First aplogies if theres already a step by step procedure on how to ping to this switch in this forum. I only have one computer available to me at the moment and I would like to simply ...
Retired_Member
Apr 18, 2017Hi marcosgu,
Welcome to the community! ![]()
At first, the IP address that you get from Wireshark is multicast IP(239.255.255.250), not Switch IP address, obviously ping this IP is unreachable.
If you want to get Switch IP address, I suggest you discover switch with Smart Control Center (SCC) software. And this tool can discover, manage and login Switch with HTTP. You could download this tool from Netgear downloadcenter with below link:
http://downloadcenter.netgear.com/
EricZ
NETGEAR employee
marcosgu
Hi EricZ,
Ok thanks! ill try that and post later if it works or not
- marcosguApr 18, 2017Aspirant
Ok so I installed the smart control software (v1.1.3.3) off the netgear website and when i go to "discover" i see no devices listed at all. I made sure that the ethernet connection adapter (under the adapters tab) was checked off.
I dont know if it makes a difference but I tried both ways of assigning an iP address and assigning an IP address automatically (DHCP) and both ways I see nothing listed. i saw somewhere that there is another possible software called Prosafe Plus Utility.
I am going to look and read some more.
- Retired_MemberApr 18, 2017
Hi marcosgu,
Sorry, as your switch gs105v4 is plus switch, it only support Prosafe Plus Utility tool to discover. SCC only can discover Smart switch.
So could you try to discover gs105v4 with Utility again?
ok ill go and install ProSafe Plus and post back afterwards
hey thanks for your help :smileyhappy:
