ICT_Team's avatar
ICT_Team
GS105V4 led light issue
All The led lights on my GS105V4 switch have just started blinking and i have lost connection on my 2 computers connected on the switch. The lights stops blinking when i unplug the ethernet cable from the switch. I have tried to plug 1 computer at a time on different switch ports but the issue persists. I have tried to powercycle the switch but this did not resolve the issue. Can you please let me know whats causing this issue?
Regards
Reg
  • HI JennC and DaneA
    Thank you for your responce. The switch was connected to the router. I found that the switch is faulty since all the led lights kept flashing or turn on and off when i unplugged all the network cables from the switch. I have replaced the switch with a new one.
    Regards
    ICT_Team
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello ICT_Team,
    GS105v4 is a passthrough gigabit switch that does not have any configuration. Its main purpose is to add more LAN ports to a router. It has no capability of broadcasting IP addresses on a network that is why it is router dependent.
    Blinking LEDs mean there is an activity going on between the device that is connected to that port and the switch.
    If the switch is connected to a router, remove the switch from the router and connect the computers to the router directly. There should be at least 2-3 computers connected straight to the router. Then, test the connection on these computers, see if they all get online at the same time with no issues. In this way, you will know if the router's LAN ports are working on the network. It is important to check this as the switch will depend on the LAN ports of the router.
    Once you are sure the routers LAN connections to computers or any LAN device are working with no problem, check the LEDs on the switch. While the switch is not connected to the router, connect one computer to the switch and observe the LED for the port where you connected the computer. Do the same on all other ports on the switch, in that way, you will be able to know which port is no longer working.
    Below is a list of LED activities of the switch:
    both right and left LEDs are lit up - there is a link and it is running on 1000mbps (1gbps)
    left LED lit up - link is running on 100mbps
    right LED lit up - link is running on 10mbps
    blinking LED - there is activity on the link
    LED is off - no link
    Hope this helps.
  • DaneA's avatar
    DaneA
    Hi ICT_Team,
    As a follow-up question to what JennC has shared unto you,  is your GS105V4 directly connected to a router or another switch or modem/router or modem-only device?
    I look forward to your response.:smileyhappy:
    DaneA
    NETGEAR Community Team
    • ICT_Team's avatar
      ICT_Team
      HI JennC and DaneA
      Regards
      ICT_Team
      • DaneA's avatar
        DaneA
        Hi ICT_Team,
        You are welcome! :smileyhappy:
        We're glad that you have isolated the problem and the replacement switch is working fine.
        Cheers,
        DaneA
ProSupport for Business
