ICT_Team
Sep 17, 2015Aspirant
GS105V4 led light issue
All The led lights on my GS105V4 switch have just started blinking and i have lost connection on my 2 computers connected on the switch. The lights stops blinking when i unplug the ethernet cable fro...
- Sep 22, 2015
HI JennC and DaneA
Thank you for your responce. The switch was connected to the router. I found that the switch is faulty since all the led lights kept flashing or turn on and off when i unplugged all the network cables from the switch. I have replaced the switch with a new one.
Regards
ICT_Team
DaneA
Sep 21, 2015NETGEAR Employee Retired
Hi ICT_Team,
As a follow-up question to what JennC has shared unto you, is your GS105V4 directly connected to a router or another switch or modem/router or modem-only device?
I look forward to your response.:smileyhappy:
DaneA
NETGEAR Community Team
- ICT_TeamSep 22, 2015Aspirant
HI JennC and DaneA
Regards
ICT_Team
