Labdoc1
Jan 11, 2021Luminary
10 Gigabit switch for RN526x SMB network
I have a new-to-me RN526x, which has 2x10G copper ethernet ports. Currently, it is connected to a Netgear GS108E switch (1 Gigabit x 8 ports). I would like to update the network with a 10G switch and...
- Jan 12, 2021
Labdoc1 wrote:
Good to know. What is your subjective impression of the noise from the fans?
The switch is in the basement, and is co-located with other equipment (several ReadyNAS and a PoE switch). So I don't think a sound measurement (or a subjective impression) would give you any good information, given the mix of equipment.
Acoustic noise is spec'd at 36.7 dba @ 25C on the datasheet (the XS716E is a bit quieter, at 33.9 dba).
Labdoc1
Jan 12, 2021Luminary
Good to know. What is your subjective impression of the noise from the fans? If you have a smart phone sound level app, would you take a measurement at, say 25 cm (10")?
Jan 12, 2021Guru - Experienced User
