Retired_Member
Jul 11, 20171002030001 - Commit failed when making or checking permissions after firmware 6.7.5 update
My ReadyNAS 214 device has been running very smoothly for months. I use it for backing up and storing a lot of static content on my home network. This morning I noted that I could not copy files from...
Jul 12, 2017Guru - Experienced User
Look in the log zip at volume.log. Towards the bottom you'll see a section header of === df -h ===
Right below that you'll see something like this:
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 3.7G 574M 3.0G 17% /
tmpfs 1009M 0 1009M 0% /dev/shm
tmpfs 1009M 532K 1009M 1% /run
tmpfs 505M 656K 504M 1% /run/lock
tmpfs 1009M 0 1009M 0% /sys/fs/cgroup
/dev/md127 927G 20M 925G 1% /data
/dev/md127 927G 20M 925G 1% /home
/dev/md127 927G 20M 925G 1% /apps
Can you post those lines from your log?
- Retired_MemberJul 12, 2017
Surely, here you go. What does that tell you besides the use amount?
=== df -h ===
/dev/md0 3.7G 1.1G 2.4G 32% /
tmpfs 1009M 944K 1008M 1% /run
tmpfs 505M 1.1M 504M 1% /run/lock
/dev/md127 17T 12T 4.7T 72% /data
/dev/md127 17T 12T 4.7T 72% /apps
/dev/md127 17T 12T 4.7T 72% /home
/dev/sdf1 3.6T 1.6T 2.1T 44% /media/USB_HDD_2
/dev/sde1 3.6T 633G 3.0T 18% /media/USB_HDD_3- StephenBJul 12, 2017Guru - Experienced User
It tells me that your OS partition is not full, which rules out one possible cause.
This is higher than it normally is (note mine was about 17%) but not anywhere close to full.
I don't have a good next step in mind though. If a Netgear mod requests your logs, it'd be good to provide them for Netgear's analysis.
Thanks - I hope they do reply; my backups are not running right now and that makes me twitchy.
