Retired_Member
Jul 11, 20171002030001 - Commit failed when making or checking permissions after firmware 6.7.5 update
My ReadyNAS 214 device has been running very smoothly for months. I use it for backing up and storing a lot of static content on my home network. This morning I noted that I could not copy files from...
Retired_Member
Jul 12, 2017Surely, here you go. What does that tell you besides the use amount?
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 3.7G 1.1G 2.4G 32% /
tmpfs 1009M 0 1009M 0% /dev/shm
tmpfs 1009M 944K 1008M 1% /run
tmpfs 505M 1.1M 504M 1% /run/lock
tmpfs 1009M 0 1009M 0% /sys/fs/cgroup
/dev/md127 17T 12T 4.7T 72% /data
/dev/md127 17T 12T 4.7T 72% /apps
/dev/md127 17T 12T 4.7T 72% /home
/dev/sdf1 3.6T 1.6T 2.1T 44% /media/USB_HDD_2
/dev/sde1 3.6T 633G 3.0T 18% /media/USB_HDD_3
Jul 12, 2017Guru - Experienced User
It tells me that your OS partition is not full, which rules out one possible cause.
This is higher than it normally is (note mine was about 17%) but not anywhere close to full.
I don't have a good next step in mind though. If a Netgear mod requests your logs, it'd be good to provide them for Netgear's analysis.
- Retired_MemberJul 12, 2017
Thanks - I hope they do reply; my backups are not running right now and that makes me twitchy.
- jak0lantashJul 12, 2017Mentor
Perhaps your data volume is mounted Read-only.
Look for BTRFS messages inside dmesg.log and systemd-journal.log, and for md127 in mounts.log, and paste the beginning of btrfs.log here.
Thanks for the reply. Inside dmesg.log, there are a large number of the following lines, about 12 per second:
- [Wed Jul 12 07:43:37 2017] BTRFS critical (device md127): unable to find logical 2595263971328 len 4096
Inside systemd-journal.log, there were 2246 instances of:
Jul 11 07:37:08 [redacted] kernel: BTRFS critical (device md127): unable to find logical 2595263873024 len 4096
Inside mounts.log:
/dev/md127 on /data type btrfs (ro,noatime,nodiratime,nodatasum,nospace_cache,clear_cache,subvolid=5,subvol=/)
/dev/md127 on /apps type btrfs (ro,noatime,nodiratime,nodatasum,nospace_cache,clear_cache,subvolid=257,subvol=/.apps)
/dev/md127 on /home type btrfs (ro,noatime,nodiratime,nodatasum,nospace_cache,clear_cache,subvolid=256,subvol=/home)
/dev/md127 on /run/nfs4/home type btrfs (ro,noatime,nodiratime,nodatasum,nospace_cache,clear_cache,subvolid=256,subvol=/home)Looks like read only if "ro" is an indication
The first segment of the btrfs.log:
Label: '11b7bc56:data' uuid: bfc1ea85-d4ed-4b14-a0dd-357b1b85a202
Total devices 1 FS bytes used 11.72TiB
devid 1 size 16.36TiB used 11.75TiB path /dev/md127=== filesystem /data ===
Data, single: total=11.74TiB, used=11.72TiB
System, DUP: total=8.00MiB, used=1.28MiB
System, single: total=4.00MiB, used=0.00B
Metadata, DUP: total=1.50GiB, used=717.62MiB
Metadata, single: total=8.00MiB, used=0.00B
GlobalReserve, single: total=252.00MiB, used=0.00B
=== subvolume /data ===
=== btrfs dump-super /dev/md127
superblock: bytenr=65536, device=/dev/md127*[redacted] is my modification for server name
Thanks,
Michael
