Retired_Member
Jul 11, 20171002030001 - Commit failed when making or checking permissions after firmware 6.7.5 update
My ReadyNAS 214 device has been running very smoothly for months. I use it for backing up and storing a lot of static content on my home network. This morning I noted that I could not copy files from...
jak0lantash
Jul 12, 2017Mentor
Sounds like a good configuration.
BTRFS quotas can be enabled on the volume even if there is no quota set on the shares. To avoid confusion, I tend to call the first one quota accounting. If you don't use quotas on any share, you should disable quota accounting.
You should still check the health of the drives in disk_info.log. If you look at the alert thresholds for the drives, they're insane imo: https://kb.netgear.com/30046/ReadyNAS-OS-6-Disk-Failure-Alerting
Retired_Member
Jul 12, 2017Wow, that is a pretty forgiving threshhold. I broke the piggy bank on the drives and got the WD RED NAS drives. They seem to be doing great. All four look a lot like this:
Device: sda
Controller: 0
Channel: 0
Model: WDC WD60EFRX-68L0BN1
Serial: [redacted]
Firmware: 82.00A82
Class: SATA
RPM: 5700
Sectors: 11721045168
Pool: data
PoolType: RAID 5
PoolState: 1
PoolHostId: 11b7bc56
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 43
Start/Stop Count: 16
Power-On Hours: 7905
Power Cycle Count: 16
Load Cycle Count: 32
- Retired_MemberJul 12, 2017
I think I found the original error. And, as I try to copy data out, it seems most of my shares are inaccessible. Thank goodness I am paranoid and have a backup of all this data. Not a happy camper.
Jul 11 07:07:44 [SERVER] kernel: WARNING: CPU: 3 PID: 2117 at fs/btrfs/extent-tree.c:3654 btrfs_start_dirty_block_groups+0x280/0x444()
Jul 11 07:07:44 [SERVER] kernel: BTRFS: Transaction aborted (error -22)
Jul 11 07:07:44 [SERVER] kernel: Modules linked in: vpd(PO)
Jul 11 07:07:44 [SERVER] kernel: CPU: 3 PID: 2117 Comm: btrfs-transacti Tainted: P W O 4.4.68.alpine.1 #1
Jul 11 07:07:44 [SERVER] kernel: Hardware name: Annapurna Labs Alpine
Jul 11 07:07:44 [SERVER] kernel: [<c0015980>] (unwind_backtrace) from [<c0012388>] (show_stack+0x10/0x14)
Jul 11 07:07:44 [SERVER] kernel: [<c0012388>] (show_stack) from [<c039a9f0>] (dump_stack+0x94/0xa8)
Jul 11 07:07:44 [SERVER] kernel: [<c039a9f0>] (dump_stack) from [<c001ffd4>] (warn_slowpath_common+0x84/0xb4)
Jul 11 07:07:44 [SERVER] kernel: [<c001ffd4>] (warn_slowpath_common) from [<c0020034>] (warn_slowpath_fmt+0x30/0x40)
Jul 11 07:07:44 [SERVER] kernel: [<c0020034>] (warn_slowpath_fmt) from [<c029e21c>] (btrfs_start_dirty_block_groups+0x280/0x444)
Jul 11 07:07:44 [SERVER] kernel: [<c029e21c>] (btrfs_start_dirty_block_groups) from [<c02b0128>] (btrfs_commit_transaction+0x154/0xc0c)
Jul 11 07:07:44 [SERVER] kernel: [<c02b0128>] (btrfs_commit_transaction) from [<c02ab2f4>] (transaction_kthread+0x1f4/0x204)
Jul 11 07:07:44 [SERVER] kernel: [<c02ab2f4>] (transaction_kthread) from [<c003a6c0>] (kthread+0xfc/0x114)
Jul 11 07:07:44 [SERVER] kernel: [<c003a6c0>] (kthread) from [<c000f368>] (ret_from_fork+0x14/0x2c)
Jul 11 07:07:44 [SERVER] kernel: ---[ end trace 3fa7939600f37903 ]---
Jul 11 07:07:44 [SERVER] kernel: BTRFS: error (device md127) in btrfs_start_dirty_block_groups:3654: errno=-22 unknown
Jul 11 07:07:44 [SERVER] kernel: BTRFS info (device md127): forced readonly
