Retired_Member
Jul 11, 20171002030001 - Commit failed when making or checking permissions after firmware 6.7.5 update
My ReadyNAS 214 device has been running very smoothly for months. I use it for backing up and storing a lot of static content on my home network. This morning I noted that I could not copy files from...
jak0lantash
Jul 12, 2017Mentor
Good job for having a good backup! I'm glad you didn't lose any (important) data.
Retired_Member
Jul 13, 2017Interesting thoughts during recovery:
I decided to try the non-brute-force approach to this.
In a good twist of fate, my last backups ran about two hours before the fault on the 11th. This rarely happens. I unmounted the backup drives from the NAS. Then, I set up my old NAS (Ultra 4) and started copying files over from the problem NAS. I quickly realized a number of my folders were inaccesible. I copied the two (of 10) which i could and then performed a Reinstall OS, as I had read if fixes some security issues on the data volume.
Interestingly, when I rebooted, all of my folders were accessible again. I immediate started a copy of the remaining 8 folders. My optimism was short-lived, though, as, while the length copy took place, several of the folders became inaccessible again. I've managed 3 more folder sets. I'm going to try the OS reinstall again once they complete and see if I can get the remaining folders. If not, I'll rely on backup.
Once the data transfer is done, I'll do a full factory reset on the current NAS and then move some content back in and watch it like a hawk.
Will update so future generations have a path forward.
- jak0lantashJul 13, 2017Mentor
You can also look at "btrfs restore".
https://btrfs.wiki.kernel.org/index.php/Restore
https://btrfs.wiki.kernel.org/index.php/Manpage/btrfs-restore
- Retired_MemberJul 13, 2017
I actually have been looking at this already, but I'd need access to the shell and every time I try to add that or grant it to any users, I get the original 1002030001 error. I'd also, from what I can tell, need the telnet user name and password in Tech Support mode to be able to get to the shell via PuTTY.
I was actually planning, after the data copy, to try something like this with some info I've found while searching. Though much of it is very old and I suspect the un/pw are different for my model. I'll give it a go before the factory reset.
In any case, I re-installed the OS one more time on the problematic device again and it keeps restoring access long enough for me to copy content out. I suspect by the end of the day I'll have everything out and can get going on the full reset. Hopefully that solves the issue permanently.
Try to access the following URL (put the NAS IP or name instead - try https if not response): http://NAS_IP/dbbroker?start_svc=ssh
Using Tech Support mode isn't that easy, everything must be done manually. But if you want the password, you can find on Internet.
btrfs restore doesn't need the volume to be mounted.
