Retired_Member
Jul 11, 20171002030001 - Commit failed when making or checking permissions after firmware 6.7.5 update
My ReadyNAS 214 device has been running very smoothly for months. I use it for backing up and storing a lot of static content on my home network. This morning I noted that I could not copy files from...
jak0lantash
Jul 13, 2017Mentor
The point of the dbbroker command to enable SSH so you didn't need to go to Tech Support Mode...
I wouldn't have done btrfsck --repair at all.
Retired_Member
Jul 13, 2017Ah, lessons learned. However, it seemed to have no effect - I rebooted and everything is as it was. I'm running a memory test overnight to make sure I'm not rebuilding a machine that has a flaw waiting to strike. Any other suggestions before I reset?
