Retired_Member
Jul 11, 20171002030001 - Commit failed when making or checking permissions after firmware 6.7.5 update
My ReadyNAS 214 device has been running very smoothly for months. I use it for backing up and storing a lot of static content on my home network. This morning I noted that I could not copy files from...
jak0lantash
Jul 13, 2017Mentor
If there is any data you couldn't copy, you can try 'btrfs restore'.
I'd advise you to inspect the data you copied, to confirm that the files aren't corrupt, etc.
