bjcool
Dec 03, 2017Aspirant
1002030001 Commit failed
Hi everyone, I recently upgraded my firmware from 6.2.2 - 6.9.1 Everything seems ok, I can still access my files through the network but when I want to watch movies on the ps4, I noticed the net...
mdgm-ntgr
Dec 03, 2017NETGEAR Employee Retired
Did you update from 6.2.x to 6.5.2 as the Release Notes communicates is necessary before updating to 6.9.1?
- bjcoolDec 03, 2017AspirantHi mdgm,
Thanks for your reply. I read the notes and what i think, i remember is that mine originally was on 6.2.2 and notes said if its below 6.2.1, you'll need to do that right. But if 6.2.2, you can upgrade automatically. When i did do the firmware upgrade, it upgraded it to a firmware (can't remember which one is was) automatically, then rebooted, then another firmware upgrade to 6.9.1. If i was suppose to upgrade the firmware manually to 6.5.2, then i didn't do it.... =(....does this mean I've stuffed up my readynas....is there a fix for that....??? Now im so stressed.... =( =(=( - bjcoolDec 04, 2017Aspirant
Hi mdgm,
I checked the logs:
Sun Dec 3 2017 2:12:14
System: ReadyNASOS service or process (readynasd) was restarted.
Sun Dec 3 2017 2:11:30
System: Firmware was upgraded to 6.9.1.
Sun Dec 3 2017 2:11:31
System: ReadyNASOS background service started.
Sun Dec 3 2017 2:11:27
Volume: Less than 5% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
Sun Dec 3 2017 2:07:44
System: The system is rebooting.
Sun Dec 3 2017 1:58:33
System: Firmware was upgraded to 6.5.2.
Sun Dec 3 2017 1:58:35
Sun Dec 3 2017 1:58:32
Volume: Less than 5% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.Looks like it did upgrade to 6.5.2 then 6.9.1.
I was suppose to update to either 6.2.5 or 6.3.5 then to 6.5.2 but I didn't. Does this mean I will have to back up the 3.63 TB of data to an external hard drive, then do a factory /reset to fix this issue I'm having?
