bjcool
Dec 03, 2017Aspirant
1002030001 Commit failed
Hi everyone, I recently upgraded my firmware from 6.2.2 - 6.9.1 Everything seems ok, I can still access my files through the network but when I want to watch movies on the ps4, I noticed the net...
mdgm-ntgr
Dec 03, 2017NETGEAR Employee Retired
Did you update from 6.2.x to 6.5.2 as the Release Notes communicates is necessary before updating to 6.9.1?
bjcool
Hi mdgm,
Thanks for your reply. I read the notes and what i think, i remember is that mine originally was on 6.2.2 and notes said if its below 6.2.1, you'll need to do that right. But if 6.2.2, you can upgrade automatically. When i did do the firmware upgrade, it upgraded it to a firmware (can't remember which one is was) automatically, then rebooted, then another firmware upgrade to 6.9.1. If i was suppose to upgrade the firmware manually to 6.5.2, then i didn't do it.... =(....does this mean I've stuffed up my readynas....is there a fix for that....??? Now im so stressed.... =( =(=(
